Register Now! Help
Logo
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Depressurization cooling effect #
User is offline   afd
  • Veteran Member
  • PipPipPip
  • Group: Members
Neutral
Posted 19 March 2010 - 11:41 PM
If I have a vessel containing ethylene at 21 barA and -18°C and I isolate it and begin depressurizing it to flare.
What is the approximate temperature the gas in the vessel can reach when the pressure becomes 2 bar A?
Thanking you all in advance for your information.
Afd
Page 1 of 1
Other Replies To This Topic
User is offline   fallah
  • ChE Jedi
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Neutral
Posted 20 March 2010 - 01:47 AM
Afd
Is the case a cold depressurizing (no heat input)?
User is offline   afd
  • Veteran Member
  • PipPipPip
  • Group: Members
Neutral
Posted 20 March 2010 - 06:17 AM
Yes the vessel in question is insulated by cold insulation(Poly Urethane Foam) and depressurizing is done by opening a manual vent valve to the flare. What will the approximate temperature be of the ethylene gas in the vessel if the manual vent valve is closed at around 2 barg.
Afd
  • ChE Jedi
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Neutral
Posted 20 March 2010 - 09:13 AM
Afd
You need to do dynamic simulation with proper software,e.g. PRO/II.
Prior to writing PRO/II input,the following calculation should be performed:
-Total volume of the circuit to be depressurized
-Total liquid volume
-Total gas volume
The circuit that is assumed as a hypothetical vessel,is considered as filled with the actual amount of liquid and vapor at operating pressure and temperature.
Initial pressure would be design pressure of the circuit (here vessel)
Final pressure would be 1 barg
Initial temperature should be equal to -18 C
Final temperature of the gas would be obtained from fluid T and P vs time plot as an output of the software
This post has been edited by fallah: 20 March 2010 - 09:16 AM
User is offline   prasad54
  • Member
  • PipPip
  • Group: Members
Neutral
Posted 23 March 2010 - 12:21 PM
You need to first decide how to model the depressurization themodynamically using a proper equation of state. For ethylene using Benzler-Koch diagarm describing its VLE and considering an Isentrpoic depresization, you can model it in ASPEN PLUS as a heater block setting equal entropy at inlet and oulet and varying the temperature. This would give you the temperature of gas.
As an intial guess you will get around -100°C as you are at very low temparature. The material of the vessel should be SS.
User is offline   go-fish
  • ChE Jedi
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Neutral
Posted 23 March 2010 - 04:53 PM
View Postprasad54, on 23 March 2010 - 12:21 PM, said:
Based on the above approach, it should be -90 C and vapor fraction is 0.44 after isentropic throttling.However, these calcs are based on depressurization from the 21 bara, -18 C to 2 bara. Could be different if you use your starting point as design pressure of equipment which could be higher than 21 bara.
@ fallah, could you please elaborate on why would this be a time dependent case? I am not highly experienced, could certainly use more knowledge.
Page 1 of 1
  Topic Forum Started By Stats Last Post Info
New Replies Refining With Triglycerides
Negative effect of triglycerides on unit
Industrial Professionals Claire
  • 0 Replies
  • 1,094 Views
New Replies Costing Analysis For Cooling Tower Student balex
  • 1 Reply
  • 1,618 Views
New Replies Attachments Direct-Fired Reboiler Sizing
Effect of Change in Heating Value
Industrial Professionals P.Engr
  • 8 Replies
  • 769 Views
New Replies Cooling Tower For Steam Reforming Student balex
  • 5 Replies
  • 3,190 Views
New Replies Cooling Water Booster Pump Industrial Professionals wnovaes
  • 4 Replies
  • 4,336 Views
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
