Register Now! Help
Logo
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
How To Add Tbc? #
User is offline   imtinan mohsin
  • Veteran Member
  • PipPipPip
  • Group: Members
Neutral
Post icon  Posted 14 July 2006 - 01:43 AM
Tertiary Butyl alcohol (TBC) is usd as an antioxidant for storage of 1,3-butadiene for long periods. The required range of TBC in butadiene should be from 50 - 100 ppm. we have a stock of 20 MT. when we have analyzed for TBC, it came out to be 10 ppm.
We have no facility to add TBC.
Can any body suggest how to add TBC?
please reply.
imtinan
Page 1 of 1
Other Replies To This Topic
User is offline   sgkim
  • ChE Jedi
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Neutral
Posted 16 July 2006 - 12:54 AM
moshin:
Use a "line mixer('static mixer')" with a "dispenser (a small liquid 'injection pump')" on the discharge and suction side of the pump respectively. To every 1000 kg of feed, inject 0.065 g +/- 0.025 g of TBC. The injection and mixing would preferrably be done during transfer of 1.3BD from one tank to another.
If you need a better homogeniety of local concentration in the holding tank after transfer, circulate the liquid by pump with "tank mixing nozzle('tank mixer')" on the inside nozzle tip in the tank, analyze the concentrations of samples taken periodically, and check the standard deviation until it meets your anticipation. If things go well, the mixing time would be less than 30 minutes.
Search web materials using the key words marked with single- or double quotation marks above.
Stefano
Page 1 of 1
  Topic Forum Started By Stats Last Post Info
New Replies How Blanketing Reduces Evaporation Losses Tank Blanketing and Venting Conchubhar
  • 6 Replies
  • 2,306 Views
New Replies Attachments How To Get The Latest Cepci
The Chemical Engineering Chemical Plant Index
Student pjadams
  • 7 Replies
  • 7,399 Views
New Replies Side Draw Simulation In Hsys
How to simulate side draw
Chemical Process Simulation fifi
  • 7 Replies
  • 892 Views
Locked Topic Site Updates For March 4, 2008
Two (2) new editions of ChExpress added
Site Updates admin
  • 0 Replies
  • 3,169 Views
New Replies How To Model Reformer For Naphtha Chemical Process Simulation satish babu garikapati
  • 3 Replies
  • 3,980 Views
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
