Dear gentlemen,
I am using hysys building butene, butane splitters.
Usually, PR model is used for hydrocarbon system with non-polar or slightly polar component. In this case, the components are non-polar. Also, the operating pressure is not too high for activity coefficient (it means PRSV model is not necessary).
Could anyone give me some suggestion that which property package is better for this case or in your past job, you use other property package (such as COMthermo)?
Many Thanks,
David
Page 1 of 1
Hysys Property Package Selection #
Page 1 of 1
Other Replies To This Topic
Posted 07 February 2010 - 10:10 AM
Peng-Robinson is just fine. You are dealing with true components, with fully defined properties in HYSYS database. This one is straightforward task, no headache or doubts.
Posted 20 February 2010 - 08:25 PM
Just go to the aspentech support website and look for thermodynamical packages, a case study you will find.
http://support.aspentech.com/
Best regards,
GERARDO VILLAMIZAR PLATA
Best regards,
Page 1 of 1
| Topic | Forum | Started By | Stats | Last Post Info | |
Air Seperation Using Hysys
Chemical Process Simulation | mina |
Feed Air Source For Nitrogen Generation Package
Industrial Professionals | Speedy |
Simulation problems with HYSYS |
Chemical Process Simulation | Monolina M |
Unconverge Column
Hysys based |
Refining, Hydrocarbons, Oil, and Gas | Olufemi |
User Variables In Hysys
Using 'user variables' in dynamic mode |
Chemical Process Simulation | djdg |
Help
