I am currently pursuing my Masters and as part of my dissertation I am trying to simulate an extractive distillation column for Butadiene recovery from C4 cut. A brief description of my system:
Feed:
C4 mix
Aim:
To Recover maximum Butadiene from the bottom of the column and remove Butenes at the overhead.
Solvent:
A mixture of Acetonitrile-ethanol-water is being used as solvent in the system.
The data I have on hand is from a running plant. From a search on the internet I have understood that NRTL fluid package is best suited for the system.
The problem I have is that the simulation results come nowhere close to the plant data.
I have tried altering the various degrees of freedom and even tried other fluid packages but to no avail. My supervisor thinks that simulation in Aspen Plus might yield results. Is it possible that Aspen Plus can yield results with the same set of data?? Can you please suggest a solution to my problem...Any help is highly appreciated...
Thanks & Regards,
Monolina
Butadiene Recovery From C4 Cut (hysys Simulation)
Started by Monolina M, Sep 14 2008 05:00 AM
Posted 14 September 2008 - 05:00 AM
Posted 14 September 2008 - 10:51 AM
Dear,
Just want to know from you that did you model your column as built or the column template in Hysys. If you configure the as built model by making some changes in your solver tab of the column property view tab I hope you will be near to the plant results. Could you just give the details like your feed condition and the column details. So that it would be easy for members to give specific suggestions to make your simulation model perfect. Waiting for your comments.
Posted 17 September 2008 - 09:10 AM
I modelled my column in a new case. My feed is a liquid feed C4 mix at a temp of 25 C and pre 11.5 kg/cm2 ,which is heated to 55C and then fed to the column. The column pressure is 3.9 kg/cm2. The feed stage entry is at 13, solvent entry at 84 stage.Total no. of stage 95. The stages are numbered from bottom. A recycle stream which is the overhead from a downstream column is fed to the 1st stage. The temp of the vap recycle stream is 71C and pre 4.5 kg/cm2. The solvent temp is 50C. The feed composition as follows:
n-butane .0145
1-butene .11
i-butene .23
cis2butene .06
1,3 butadiene .53
vinyle acetylene .02
Solvent consist of 77% acetonitrile, 15% water and 7.5% ethanol.
n-butane .0145
1-butene .11
i-butene .23
cis2butene .06
1,3 butadiene .53
Posted 17 September 2008 - 09:21 AM
Further the composition of the recycle from the second column to the first column is as follows:
n-Butane 0.039
1-Butene 0.1002
i-Butene 0.156
cis2-Butene 0.071
1,3-Butadiene 0.927
VnylAcetylene 0.006
Acetonitrile 0.171
Ethanol 0.0239
Water 0.004
All values are on a mass fraction basis...Hope you can throw further light on where I am going wrong with my simulation...
n-Butane 0.039
1-Butene 0.1002
i-Butene 0.156
cis2-Butene 0.071
1,3-Butadiene 0.927
VnylAcetylene 0.006
Acetonitrile 0.171
Ethanol 0.0239
Water 0.004
Posted 24 September 2008 - 08:14 AM
Dear,
Please update the complete Data. Nobody could could model your case in any simulator. Aspen Plus or any simulator will not assume any input for you. So please furnish the complete data so that I could model your system and will send you the file as you are student I should help you. I am attching an excel sheet which I expect you to furnish the inputs required to model your system.
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
