Hi Everyone,
I am in middle of preparation of Datasheets for Suction Heaters in Crude Oil products Storage Tanks.
I want to know, how I can design those Suction Heaters? Are they must specify by Tank Vendors or
there is any design procedure for Sizing of those.
I am very grateful if someone could give me an advice.
Afshin
Suction Heater
Started by Afshin445, Sep 24 2008 01:56 AM
Posted 24 September 2008 - 01:56 AM
Posted 24 September 2008 - 11:00 AM
QUOTE (Afshin @ Sep 23 2008, 10:56 PM) <{POST_SNAPBACK}>
Are they must specify by Tank Vendors or there is any design procedure for Sizing of those.
Afshin,
I would think it prudent to consult with vendors of these products. While we could imagine scenarios - starting temperature of the tank's contents, desired oil temperature going to the pump, etc. - we would really be making a lot of assumptions about how much of the heat gets to where it is needed (fluid going to pump) vs. heat that just dissipates in the tank. They should know from experience what size heater would be needed to achieve the results you desire.
Posted 25 September 2008 - 01:29 AM
Djack,
Thank you for your good advice. But I don't know any Vendors
can supply Suction Heaters. Do you have name and address (or website) of them.
Afshin
Afshin
Posted 25 September 2008 - 02:50 PM
Afshin,
You need to get better acquainted with Google. You could try TMEC (tmec.com) or Koch Brown Fintube (kochheattransfer.com) as a starting point. Using Google, look for "Suction Heaters" or "Bayonnet Heaters".
Good luck.
Good luck.
Lng Boil Off Gas Compressor Suction DrumStarted by Guest_Lyne_* , 04 Jun 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Screw Compressor Suction Pressure DeterminationStarted by Guest_Deicide Dunkelheit_* , 22 Jan 2025 |
Closed Loop Pump Suction Line Sizing CriteriaStarted by Guest_Afshin445_* , 30 Aug 2024 |
