Can any person help me to know the calculation of Compressibility factor of natural gas or normal gas,
With regards
mkhan
Compressibility Factor Of Natural Gas
Started by mkhan, Nov 30 2008 02:27 AM
Posted 30 November 2008 - 02:27 AM
Posted 30 November 2008 - 02:42 AM
QUOTE (mkhan @ Nov 30 2008, 03:27 AM) <{POST_SNAPBACK}>
With regards
mkhan
With regards
mkhan
Use the compressibility factor spreadsheet I have posted on:
http://www.cheresour...hl=spreadsheets
In the spreadsheet, give the mole fraction of the indivdual components of your natural gas and provide the Critical Pressure and Temperature of the individual components. Calculate the pseudo-critical pressure and temperature of the gas mixture. Provide the values of these in the input section as well as your operating pressure and temperature and voila you will have your compressibility factor z as well as density of the gas mixture @operating temperature and pressure.
Posted 01 December 2008 - 12:10 AM
Dear Ankur,
Thanks for your response,
In a case of design new line for natural gas , Z factor will be calculated on operating or design temperature & pressure?
mkhan
mkhan
Posted 01 December 2008 - 04:29 PM
QUOTE (mkhan @ Nov 30 2008, 09:10 PM) <{POST_SNAPBACK}>
Depends on whether you want the operating or design compressibility. Seriously, your question makes no sense. Tell us what you want to calculate and we can help.
Posted 02 December 2008 - 12:27 AM
i want to know , calculation of flow rate and required velocity for NG new designed line for pipe sizing.
mkhan
mkhan
Posted 03 December 2008 - 09:18 AM
To evaluate the performance of an operating or soon to be operating pipe line, you will want to use the actual or operating properties. (By evaluate, I mean to determine the velocity and the hydraulics of the system.) If you are designing the pipeline, then use design values. Design values are normally used for pipe sizing.
Posted 11 December 2008 - 06:42 AM
I can give you an Excel sheet using AGANX-19 method for Z factor of NG.
This is the most accurate method, but my excel sheet currently is not in a good presentable format.
So it will take sometime to re-work on it.
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
Predicting Fouling Factor In ReboilersStarted by Guest_ProcessEng_12_* , 12 Aug 2021 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
Increasing Raw Natural Gas Dew PointStarted by Guest_lowrentstuff_* , 18 Sep 2023 |
Purpose Of Natural Gas Saturator?Started by Guest_daraj_* , 06 Aug 2023 |
