Can anyone advise on how to calculate relieving rates from a column on reflux failure or overhead condenser failure? I am trying to set HYSYS up to calculate this using steady state mode but it is proving difficult as I am trying to model the reboiler decreaded LMTD due to higher pressure and the lack of reflux.
Patrick
Column Relief
Started by Guest_P Gallas_*, Nov 09 2004 09:56 AM
Guest_P Gallas_*
Posted 09 November 2004 - 09:56 AM
Guest_Checkmate_*
Posted 30 November 2004 - 05:09 PM
The easiest way of doing is not to use a simulator. If you already have steady state converged runs for the column, as a worse case scenario u can size the PSV for the total vapors leaving the top tray. If you want to reduce the size of the PSV u can take credit for cooling thru air cooler (if u have any on the reflux circuit). Getting the simulator to converge for higher pressure is diff proposition.
Guest_Mondolfi_*
Posted 01 December 2004 - 04:49 AM
If you're gonna model the reflux failure in steady state, I suggest you to use only simulator to obtain required process data -e.g. mol.weight, temp, pressure, Cp/Cv, etc @ relief condition-. Common practice is to assume vapor load and composition from feed stage or bottom of the column due to there's no rectification.
If you want to get fancy, then switch to dynamic model once you converge the column in stady state and stop reflux.
regards,
C.H. Mondolfi
regards,
C.H. Mondolfi
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Ethylene Glycol Purification ColumnStarted by Guest_sg21255_* , 19 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
