Full Version: One Safety Valve Protecting More Than One Equipment
Luigi
This is the case I am starting to look at and would like your always interesting comments and advice:
Steam at 150psi if sent to a pressure vessel with a design pressure of 70 psi, through a control valve. There is no safety valve on the vessel, so if the control valve fails, there is a potential overpressure. Trying to understand the protection criteria used in the design, I thought that it might have been considered the vessel as part of "system" under the concept of ASME that allows a relief valve to protect interconnected equipment.
There are two potential paths for relief, one doesn't have any block valve, but goes through a condenser and into a third vessel, with a safety valve set at 70 psi.
The other goes through a pump and reaches a column with a safety valve set at 70 psi. In this case, we have more than one block valve (normally open).
For the first path, even without a valve, I believe that there are other conditions to be met. For instance, we have to assure that under relieving conditions, the pressure on the vessel been analyzed won't be above (70 psi +10%).
For the second case, I think that relieving through a pump would be totally unpredictable, thus, unacceptable.
I would like your opinion over the applicability of the "system" concept for these two possible paths.
One additional question that derives from the first path is, assuming that the flow rate and pressures (and any other additional requirement) is complied and we accept it as an adequate relief path, would the presence of a normally open manual valve (not car-sealed) void it? That is what I would understand from the code but, wouldn't it be another case of double jeopardy?
Thank you for your input.
Environmentally, if a steam regulator fails wide open, do you want to blow just water to the atmosphere biggrin.gif or water AND chemicals mad.gif ?
Luigi
Latexman:
I am not sure I understand your point clearly, so I will add some more information I believe is related to your comment.
I am reviewing an existent design and I need to understand the criteria used for protecting the vessel from overpressure. The system has no hazardous products, but even if there was, the assumption (for the purpose of answering the qustions) should be that the existing safety valves are properly routed to a safe place.
Could you please elaborate a little more based on this?
In reality, the safety and environmental impact of the discharge of a PSV to atmosphere is tied so intricately with the pure technical solution that they cannot be separated. I know from past experience that a lot of engineers out there, act like they can, and want others to follow, especially their reviewer. In this experienced relief designer and reviewer’s opinion, the *right* solution cannot be reached unless they are considered together.
Therefore, I regretfully cannot elaborate further on my points if "the assumption (for the purpose of answering the qustions) should be that the existing safety valves are properly routed to a safe place".
AA Mishra
How come you don't understand the criteria to protect the vessel from overpressure
You check operating pressure, name plate capacity of safety valve and related alarms provided.
In case, control valve failure is bothering you so much, you change control valve from fail to open to fail to close.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
