Full Version: Ashrae Calcs For Mru Relief Devices
Rookie
ASHRAE Addendum 15c-2000 says to multiply the required relief capacity by a factor of 2.5 if there are combustible materials within 20 ft. Does this only apply to combustible and not flammable materials? If so, why doesn't it apply to flammable materials within 20 ft as well? Wouldn't flammables also contribute to the heat input (thus the required relief rate)…just as combustible materials would?
Thanks in advance for your clarifications.
JoeWong
QUOTE (Rookie @ Apr 23 2007, 03:58 PM) *
Rookie,
Suggest you to check similar post in other Forum...eg.
http://www.eng-tips.com/threadminder.cfm?pid=403
If you found answer to your post, suggest you can create a link to this post for benefits of all...
Rookie
Thanks Mr. Wong. I've found the answer. It only applies to combustible materials. Go here for more info: http://xp20.ashrae.org/stds/154.htm
JoeWong
QUOTE (Rookie @ May 7 2007, 11:00 AM) *
Rookie,
Good attitude ! Thumbs-up for you...
Invision Power Board © 2001-2009 Invision Power Services, Inc.
