I am currently specifying relief valves for a certain plant. ASME Section 8, Div 1 paragraphs U-1 & Ug-125 & ASME Section 8, Div 2, para AG-121 call for all pressure equipment rated at more than 15 psig(1.05 barg) and larger than 6" (152 mm) in diameter, width, height or cross section diagonal (no limitation on length) to be protected by a relief device.
I have identified equipment with design pressure greater than 15psig & larger than 6". Do these still require a relief device if the design pressure of the equipment has been increased to withstand the relief scenario. eg. If the relief scenario for vessel has been identified as a blocked discharge. The pump shut-off pressure is 51 barg. The vessel is then designed for a design pressure of 51 barg. Is a relief device necessary in terms of ASME 8?
Essentially, does anyone know if ANY exemptions exist in ASME 8 (eg increasing design pressure) to prevent the installation of relief valves?
Thank you.
