I have some questions...
I am doing PSV Sizing for a Shell Project. In their procedure, not all PRV sizes are available, say orifice G, J, M and N are not to be selected. In this case, I always choose the next higher size. For example, I have calculated am orifice area of 19.2cm2, orifice L is a little small so M would be enough. But since this size is not permitted to be used based on their procedure, P would be the proper size, skipping orifice sizes M and N. My questions are:
1. Isn't this relief valve oversized and there is a high risk that this will chatter?
2. I was thinking of converting it to a multiple relief valve so that I can have smaller standard orifice size that will give me closer area with my calculated value. But on the second thought, considering engineering economics, this would be more costly. Do you think changing it to multiple relief valve would be more appropriate?
Thanks!
