QUOTE (pleckner @ Aug 5 2007, 07:29 PM)
Question #1: From my point No. 2, only you and your instrument engineer can determine this. You calculate the required relieving load as if you were going to use one PSV and see if you can find one to fit. If not or it will be two big then you need to break it up into smaller PSVs.
Question #2: From my point No. 3, you can size a relief device for a fire case only, if you want to and at a higher set pressure than MAWP and still size the other relief device for the worst case of the non-fire cases at a set pressure at MAWP. This technique is more typically used when there is a chance for run-away reactions at excessive heat.
Question #3: From my point No. 4, maybe. I would let a piping designer do it if it was up to me. However, if you were using some software, say SuperChems for instance, it could give you the reaction forces as part of the output.
For point #1, it could be restricted by API 526 (some company use only API 526 standard PSV)...and further restricted by COMPANY requirements (e.g. SHELL) for whatsoever reasons (failure history, standardization, cost effective, handling, etc)
JoeWong
