Dear All:
I read in an engineering practice about conventional PSV setting:
"For conventional valves, the spring shall be set at the differential pressure between set pressure and constant back pressure"
Is there any benefit or concept behind of this statement that not setting PSV on set(design) pressure?Is this type of setting convenient?
There is also another statement that recommends using balanced PSV for:
-When two phase flow is expected
-the fluid is corrosive or toxic and psv discharging to sour gas flare
Again I can not undertand the benefit or logic(if any) behind ot this recommendation.
Your valuable comments are appreciated.
Cheers.
