QUOTE (pleckner @ Oct 18 2007, 05:54 AM)
API Standard 521 does NOT recommend the use of HIPS, it only presents this as a an option. Also, if you read through the entire discussion in Appendix E of the new API Standard 521, there are implied pitfalls all over the place and I could easily interpret fire as being one of them.
Think about it, how is a HIPS going to prevent a fire? Perhaps it can be used to minimize the chances and to aid in reducing the effects but I can't see how it can prevent one.
Process safety system evaluation and design also requires the use of common sense and good engineering judgement. If you're looking for back-up for what you've heard (and by the way, where or from whom did you exactly hear this from?), just apply some good old engineering judgement and also re-read the API standard, slowly and real carefully.
As designer, we are trying our best to avoid using HIPS due to reliability, availability and maintainability of the HIPS system. However, certain scenario will really push us to use HIPS.
Let take an example. A HP separator designed for 50 barg with separated liquid feeding a LP separator designed for 15 barg. Obviously there is a High pressure (HP) - Low Pressure (LP) interface here. Pressure Relief Device is generally required to protect the LP system. However, sometime the HP separator contain a very large liquid inventory as compare to LP separator. In the event, liquid control valve failure (HP separator liquid control valve) will leads to large amount of liquid from HP separator occupy the LP separator. Sudden large amount of liquid filling LP separator may leads to sudden large liquid surging to the LP separator. It is very difficult to quantify the impact of this liquid surge. Experience indicated that surging pressure could be few time higher than the LP separator design pressure. Under this scenario, HIPS may be required to be provided at the Liquid line.
Provision of HIPS on the liquid line will not protect the LP separator from other overpressure scenario e.g. external fire attack, backflow, etc. Those Pressure relief device still required to be provided on the LP separator for overpressure protection.
I do agree with Phil last paragraph "
Process safety system evaluation and design also requires the use of common sense and good engineering judgement. If you're looking for back-up for what you've heard (and by the way, where or from whom did you exactly hear this from?), just apply some good old engineering judgement and also re-read the API standard, slowly and real carefully.". Proper engineering analysis and judgment is absolutely required.
JoeWong
