Hello All,
I am a junior engineer and I am having trouble with calculating the relieving temperature for a blocked flow psv scenario.
If the normal operating temperature is T1 at Pressure P1.
Then how do I calculate the relieving temperature T2 ant P2, where P2 is the Set point + overpressure.
We had previously used the following equation
T2 = T1 * (P2/P1)
Which is Boyle's/Charles law if I remember correctly, but this is assuming an ideal gas with a constant volume and number of moles which isn't true. I believe the equation was taken out of an older version of GPSA.
If your operating temperature P1 is far smaller than your Set Pressure, then you end up with a huge temperature that is unrealistic.
I believe the we should be using isentropic compression with the following equation
T2 = T1 * (P2/P1)^(k-1/k) Where k = Cp/Cv
And this would determine our relieving temperature T2 at our relieving pressure P2.
Is this correct?
