I am starting out in work connected with marine applications and if I can get information it will save my job. I have been asked to find out:
1. Discharge pipe and calculation of the built up back pressure.
2. Stationary forces at the safety valve.
3. The best position /orientation for the discharge pipes.
The valve details are as follows:
Service: 16 BARG steam header pressure relief valve
Nozzle: FULL
Size: Inlet - 6" / Outlet - 8"
Design Type: Conventional
Fluid: Steam
State: Vapour
Density: 8.23 kgs/mtr3
Operating Pressure: 16 Bar
Set Point: 18Bar
Operating Temperature: 217deg C
Built up back pressure value: Variable/ 1BARG
Required Capacity: 64,200 kg/hr.
Any info as to calculations required would be appreciated very much.
