In a case which I am faced there is a Depropaniser reboiler into which Hydrocarbon (in shell) is heated by LP steam. The design and operating conditions are as follow:
- TEMA Type: BKU
- Design Temp. Tube side: 270˚ C Shell side: 160 ˚C
- Desigs pressure of steam system: 8 barg
- Operating pressure of steam system: 4 barg
- Design pressure of shell side: 28.5 barg
The engineering contractor has considered one PSV on the tube side (SP = 28.5 barg) whose Tail Pipe is conducted to a safe location (not to Flare). He also ignoring design pressure of steam system, considered the design pressure of the tube side equal to 28.5 barg (for external pressure) and FV (Full Vacuum for internal pressure). My questions are :
1-In the cases same as above (steam in low pressure side) we must consider ΔP of the tube side equal to shell side?
2-Is the reason that: ΔP = 28.5 (ext. press.)-FV(int. press.)=28.5 barg for the tube side in worst case?
3-Must the value of ΔP (28.5 barg) of tube side be extended to entire relevant LP steam system (piping and header)?
4-Why is the tail pipe of the PSV conducted to a safe location, since we know that in the case of PSV action on 28.5 barg, HC along with steam will certainly be released ?
5-Can we conclude in the cases using steam in tube and given as low pressure side , the 2/3 or 10/13 rules are ignored and ΔP of two sides are considered rqual?
REGARDS
