I'm looking for a way to estimate tank inbreathing/outbreathing rates during normal cooling/heating (day to night) of tanks. I've read API 2000 and I cannot find any guidance for estimating normal rates and it seems to conservative for my purpose.
Some history - The reason I'm looking for this information is because the design of our blanket system (N2) is comprised of two parts. One is the LP system which provides blanket N2 to our continuous users. The second part is the HP system which is basically a standby system that is used for blanketing during extreme consumption rates. My thought is that API2000 gives values that fall under the extreme case. However, I have not found any guidelines as to how to estimate the "normal" consumption rate. I thought about simply looking at the temperature changes throught the day and assuming the tank to be at the same temperature, but this does not consider the effects of solar radiation.
Your input is greatly appreaciated.
Wally
