Engineers Are The Best
Feb 21 2008, 10:12 AM
Hello everyone well I am a bit confused in falling film evaporators and special reactor designs in which product gases leave from the bottom of the reactor instead from the top although it is a well known fact that gases always rise due to low density.Similar is the case with the falling film evaporators.Please can you tell that if it is due to distributor at the top which forces feed gases downward with a high dynamic pressure which forces the product gases to leave from the bottom instead from the top.Please I need some help in this regard from qualified engineers who are the surfers of this forum.
themroc
Oct 27 2008, 11:51 AM
The reason the vapour is in dowmward flow is because usually at the bottom of falling film evaporators you will find that the vapour is condensed therefore "sucing" the vapour from the top to the bottom.
There are some explanations how it works on
www.fallfilmverdampfer.info
I hope this helped
