Dear all
As you know considering Fire Detector being activated , the operator is warned for manually opening BDVs remotely in orther to activation of Depressurization System.In these cases it is supposed that PSVs located in relevant Fire Zone is not activated due to depressuring occurance.
A question i want to raise: If in any fire case BDVs are activated,relief load usually we consider as "PSV Relief Load" for fire case in "Flare Load Summary Report " has been resulted from which case of fire?Is it resulted from no activation of BDV?
