When evaluating the depressuring time for a section of plant composed of some equipment and their connected piping, it is a good practice that we consider the effect of a component with the lowest thickness which in most of the cases I have seen is connected piping.(becaue at the onset of an emergency situation we should depressurise as soon as possible). If the concerned piping section thickness be less than 25 mm the depressuring should be faster(according to API 521). Suppose that following a logical trend we set the depressuring time(for example decrease the depressuring time from 15 minutes by 3 minutes for every 5 mm for thickness values lower than 25 mm). The problem arise after that, is a huge depressuring load for example depressuring a section of plant whithin 6 minutes which necessitates a flare network with huge capacity!
How to cope with this major concern?
Your valuable comments are appreciated.
