I have several situations wherein the relief temperature calculated from API 521 using the ideal gas law is much higher than the wall temperature. I found a post from Wendy a few months back, with responses from Phil L which indicated that I should perform the RV calcs based on the very high T1. In that situation F' used in the sizing equation (5) [A= F'A'/sq rt P1] is of course a nonsenical number. So which of the following approaches should I use:
1. Use API 521 eq (5) above, with F'=.01, which is the default minimum.
2. Use that equation, with F'= .045, which the standard states is the number to use when the mimimum value is unknown.
3. Use the API 520 gas equations (3.2 - 3.4) using the very high T1. In this case I need a recommendation for calculating the mass flow rate (of course normally based on BTU rate / Hvap).
Thanks for the help. I am stumped on this one.
