Hi there. I hope some one has experience in my problem:
My problem is a failure in the End Fash Gas (EFG) after cooler (38% N2 and the rest is C1). This after cooler cools down EFG from a range of (180- 155 degC) to sea cooling water(SCW) temperature (SCW temp varies from 23 to 33 deg C). The EFG is cooled to around 40 degC.
EFG is in the shell side, whereas the scw in the tube side. It is a counter-current heat exchanger, with two tube passes and one shell pass. Tube material is 70/30 Cu-Ni alloy and the shell material is Carbon steel.
This after cooler suffers from pitting corrosion in the top row of tubes, underneath the shell inlet nozzle.
The EFG flow varies from 850 T/D to 1,400T/d at an inlet pressure of 24.5 barg while the SCW flow is always kept constant at 84 kg/s with an inlet pressure of 3.5 barg.
My question is: we have 3 trains of LNG and the faliure of this exchanger take different years to fail from 1.3 year to about 3.5years.
Can somebody share information with me on the same problem? Any root cause, or a solution to avoid it in the future? Anything would be of help.
