Mr. Montemayor,
I am sure the efforts (always) that you have put in will definitely benefit the reader of this post. I just hope my contribution would trigger people to think more...
I am completely understand and agree with your intent to emphasize the fact that we can't discuss a Latent Heat of Evaporation principle in this context. The supporting statement is "When a fluid is in the super critical phase, there simply is no "liquid" phase to "evaporate". There is only one, continuous, "dense" phase that apparently behaves sometimes like a gas.".
Somehow supercritical fluid may not 100% behave like gas with low conductivity, low specific heat and low heat transfer. Let say in "
Measurements of Heat Transfer Coefficients From Supercritical Carbon Dioxide Flowing in Horizontal Mini/Micro Channels", and "
Heat Transfer and Pressure Drop of a Supercritical Pressure Fluid Flowing in a Tube of Small Diameter", they presented the Cp has singificant increase for certain pressure and temperature range. Experiment results by Yamagata et al. (1972) in the "
CFD Analyses of Heat Transfer to Supercritical Water Flowing Vertically Upward in a Tube" presented the heat transfer coefficient for supercritical fluid is high in certain temperature and pressure range. All these uncertainties have lead us to a question, should we ignore these known characteristic ?
Equation (8) to (12) are rather weak in the sense that it leads us to a condition no way you can know how much heat is entering the vessel and what kind of heat flux you will expect. Backward estimate would help us to understand the heat flux is low. Is this approach conservative ? Before i aware the special characteristic as indicated above, i would believe supercritical is gas like. But when i aware of these special characteristics for supercritical fluid, i just has NO clue with correct approach.
The only reasonable way that i can tackle is to take conservative heat input. The magic equation by API (21000A^0.82) is known to provide more conservative heat flux / heat input. This has also been recommended in the paper "Rigorously Size Relief Valves for Supercritical Fluids" presented by Ryan Ouderkirk.
One of the point that we are still struggling is the magic equation by API is base on Pool fire. Pool fire is known to have much lower heat flux than jet fire. Again, the question surfaced. Is the API magic equation conservative enough ? When we consider the jet fire impingement, the metal temperature would increase rapidly. In some/many events, the vessel fail prior to the internal pressure reach it RD or PSV set pressure. This has lead to INVALID case.
Well... I am not as lucky as you where "old timers" taught you and mentored you for many years ago. I am shame to say this but it is a fact. We only can read more, think more, take many time and effort to understand a simple concept and phenomenon....I am glad that you have the luxury of "old timers" mentoring and guiding you. On the other hand, i am glad that there are still some people like you willing to spent your time and take effort to provide guidance to us...
API use a lot of "may" and "might". Statement like "If the user considers that the preceding assumptions in 5.15.2.2 are not appropriate,..." will only lead us to think extra and find a new way to tackle the problem.
Looks forward more advice and taught from you.
Thanks in advance.
