I checked some of the projects with different Engineering companies and I found that there are two different configurations for PSV isolation valve on tail pipe:
1. Some of the companies use a flanged to flanged configuration for PSV and isolation valve (usually full bore locked open ball valve) for this the isolation valve is located upstream of expander.
2. And some of the companies use the isolation valve downstream of the expander.
I thought that the first configuration is the best one especially from economical perspective because usually the tail pipe size is two or three times (or more) the psv outlet nozzle and if you use the isolation valve upstream of the expander you can save a lot of money considering that ball valves are expensive and the number of pressure safety valves in a typical plant is great.
But I recently read in a technical article (if you are interested I can share it with you) that in recent years there have been instances in it we had a combination of psv at popping state while the isolation valve in closed position(although it is locked open)! The author explain that this is due to high induced vibration of psv when popping. So one of the recommendations of the author is that use the second configuration to prevent this failure.
What is your recommendation about discussed subject?
Many thanks in advance.
