Dear All
Currently we are having a problem with our existing water injection pump. The existing pump can only deliver up to 25,000 bbl/day at 2100 psig.
One of our well are having a problem with the its permeability that requiring higher perssure in order to fracture it. The new required pressure is at a min 2700 psig to 3000 psig. Therefore, the existing pump was not able to cater with the new requirement.
New direction has been made by installing new pump for the dedicated problematic well. The new requirement for the dedicated pump is :-
Discharge Pressure :3000 psig@5000 bbl/day
Liquid : Treated Sea water
Space : Space are very limited. Dect extension required for the new unit. Plan for the new unit to be temporarily install & commission on top of the deck.
Currently I only have 2 quotation for the above proposal. The quotation are :-
1. 10 Stages Multistage Horizontal Centrifugal Pump
Flow Rate : 146 GPM (5000 bbl/d or 33 m3/hr)
Head : 2243 feet (684 m)
Suction Pressure : 2000 psig
Discharge Pressure : 3000 psig
NPSHr : 9 feet
Design Efficiency : 57%
Design BHP : 149 HP
EOC HP : 214 HP
Driver : Diesel Engine 254 HP (Intermittent)@2300 RPM
Source of water (Suction Side) : From discharge side of the existing water injection pump
2. Reciprocating Pump
Type : Single Acting Triplex Plunger Pump
Rated Pressure : 3030 psi Max. Operating Pressure
Inlet Pressure : Min. 15-20 psi
2.75" Diameter Plungers, Tungsten Carbide Coated
Flow Rate : 131 GPM @ 260 RPM
Driver : Diesel Engine CAT 3406 325 HP@ 1800 RPM
Source of water (Inlet) : From the suction side of existing water injection pump
What was happening in my mind was I do not know which one to choose. Appreciate if any of you guys could give some advice on the pump selection either opt for centrifugal pump or reciprocating pump.
Cheer
