Currently I am working on sour water stripper unit of one of the refinery. This is extended Basic design stage of the project.
Licensor defined the sour water tank as normal conical (Fixed) Roof Tank, and the client is insisting for a floating roof tank. I am not in position to convince the client.
Project Data:
-Tank Pressure / Temp: 25 mm H2O / 51 C
-Tank dimensions: 15200mmID x 14700mm Height.
-Total Flow rate: 125t/h
-Tank material: KCS
-Sour Water Source: NHT/DHT/VDU/HCU (Upstream process units)
-Oil Skimmer package inside tank.
In our design we have Sour Water flash drum (OP= 1.0kg/cm2g) upstream of the tank, where almost all the Hydrocarbons will be removed from the sour water.
For design purpose we have considered 5wt% of hydrocarbons in sour water.
My queries:
1. What factors of sour water should I consider for the tank type selection?
2. What would be the good choice for tank type for sour water service?
3. I am worried for the effects of floating roof tank upon high quantity of hydrocarbon liquid carried than normal operation. Will there be any effect on sealing system?
I am look forward for your expert opinions.
Thank you in advance.
