QUOTE (Bill B @ Aug 26 2008, 07:05 AM)
When evaluating a relief valve to protect the shell side of an exchanger being fed the tops from a stripper (i.e. a condensing exchanger) does one use the wetted wall (liquid to vapor) approach or the unwetted wall (gas to gas) approach?
Just to understand a bit more...
Is the condenser Shell & Tube type or air-cooled type ?
Is the condenser mounted on the top of stripper ? How height is the condenser ? Do you consider jet fire is credible scenario ?
