Hi all,
I am working for blowdown-depressuring study for an existing facility's expansion. I performed the depressuring runs for it and now trying to give the data to an vendor to size the related RO's for blowdown. I have some questions, if anyone can update with any hint it would be great for me.
1) While filling up the RO-datasheet which properties should I put? Is that the Peak-flow properties or stream properties of inlet to BDV (RO) or stream properties of outlet of BDV (RO).? & WHY?
2) What would be the design pressure for the RO? is the same as the operating pressure of the upstream vessel or again the stream pressure/peak pressure?
3) If the stream is all vapor but in some cases it gives a liquid in-between or at the end of depressuring. Should I take the "liquid-phase properties' from that liquid stream or should simply say there is no liquid? WHY?
Any suggestions are welcome!
Thanks in advance.
