Full Version: C5+ Recovery From Injection Gas
ChE Forums > General Chemical Engineering Forum > Refining, Hydrocarbons, Oil, and Gas
Zauberberg
Hello to everyone,
I'm looking for applicable technologies/vendors for condensate recovery from injection gas - technologies based on solid bed adsorption and membrane systems.
Injection gas is very lean (about 3.5% weight of C5+), so mechanical refrigeration and turbo-expander plant are not attractive - which makes adsorption and membranes to be favorite options. In addition, acid gas content is quite high (3.5% weight H2S and 27% weight CO2, saturated with water). Only C5+ fraction is of interest for recovery. Injection gas pressure is 100bar, and the temperature is 50C. Net flowrate is about 4,000,000 Sm3/day.
I have some information about Shell/Engelhard's SORDECO adsorption process, but I would like to include other technologies as well, in order to find the best solution.
Any feedback from forum members is appreciated.
Best regards,
peeyar
UOP has a process called Memgaurd which they use up stream of their membrane unit
regds
PEEYAR
Zauberberg
Thanks Peeyar,
It's interesting I haven't got any response from UOP on my query, and I'm guessing what can be the reason: either the gas is too sour, or the operating pressure is too high. From what I know, membrane systems are limited for pressures up to 60bar, and many of them are limited with capacities as well. High acid gas content makes the process even more complex due to special requirements for materials of construction. Gas Sweetening Unit equipment, for example, will be cladded with Alloy 825 while piping will be made of solid Alloy 825, as usual.
However, I found some really interesting technologies available in the market - mostly adsorption-based. Turboexpander units offer some advantages but they call for special design as well, due to abovementioned high acid gas content.
Best regards,
