ahahahahha, i didint smell a rat and went away,i just was driving home, i realized what i was saying, i know that the measure of saturated water content in a gas current is Lb H20 /MMSCFD those calculations come from a long algorythm ,if u do not have water content tables and just composition ,you can see where it comes from converting your Volumetric FLOW into molar flow for example 85 MMSCFD (VOLUMETRIC FLOW ) of natural gas , you use the the convertion that says 1lbmol is 379.5Ft and divide that to the 85 MMSCFD and that will give you LBmol or pound mol i dunno how do you say it in english after that you convert your molar flow to water molar flow multyplyng it with the mole fraction and you multiply again with the Molecular weight of water to turn it into mass flow now after that you want to know how much pounds of water (LB) are per each MMSCFD of natural Gas you devide your water mass with your total gass flow, and that will give you a volumetric gass flow LB/MMSCFD some of you just said it is a mass flow, and if im correct MASS/Volume per day its a volumetric flow, mr. Art correct me if im wrong.
with that said and , said very confusingly, my trouble comes, because ive contacted an adsortion tower vendor PROCEL and they have given me a data sheet they want me to fill with specifications, and one of the specifictiatons is that i have to give them the water content or the Adsorbate requirementes in PPMV and i sinceriley only know how to calculate water content is in lbh20 /MMSCF or iin Kgh20/MMm3D so, i need to know how to take the quantity of water requiired and the one present and convert it into PPMV so i could fill the form
that said i apologize for my redaction and for the mistakes in writing ,english is not my first language
and Art you know my case i wright a lot asking questions about dehydration
PS: before somebody says " Miguel thinks PPMV is a water content measure, i know it isnt , but i would like to know how can i expresss!! my desired water content in PPMV
