I have a question regarding control valve selection. Under what conditions, we would select the full port control valve instead of reduced port? What are the differences between full and reduced ports?
Thank you very much in advance,
Control Valve Full Port Vs. Reduced Port
Started by Guest_Guest_*, Feb 12 2005 09:39 PM
Guest_Guest_*
Posted 12 February 2005 - 09:39 PM
Posted 19 March 2005 - 03:00 AM
Guest:
It is common for valves to have reduced ports, meaning that the minimum cross-sectional (flow) area of the valve may be significantly less than the cross-sectional area of the connecting pipes. Avoiding this through the use of "full port" valves can be an expensive proposition as full port valves often sell at a significant premium relative to reduced port valves.
So, why might you want a full port control valve? Well, it would be pretty rare that you would. About the only justification I can see for using one would be in situations where pressure drop is critical. Then, perhaps, you might not be able to tolerate the additional pressure drop that a reduced port valve would generate.
Doug
Doug
Leaking Ball Valve On Hot AmineStarted by Guest_chris_* , Yesterday, 06:36 PM |
Unisim Control Loop Tuning Help?Started by Guest_winchester427_* , 13 Jun 2013 |
Rupture Disc & Safety Valve SizeStarted by Guest_Dchaitanya_* , 12 Jun 2013 |
Safety Relief Valve SizingStarted by Guest_Ali_gholamalian_* , 07 Jun 2013 |
Relief Load Depressurization Valve Vs Relief ValveStarted by Guest_dtmgo1_* , 03 Jun 2013 |
