I have an application where I am transferring Liquid material from Storage tank to Truck. After transferring the liquid material I need to flush the line by using Air.
Information:
Line size: 3" (300 ft line)
I am thinking of adding the pressure regaulator on Air line, and I would like to know the required air pressure and flow at the dicharge of the regulator. Inlet air pressure of the regulator is 120 psig.
Is there any criteria (velocity/presussure drop) for Pneumatic liquid transfer?
Thanks,
Pneumatic Liquid Transfer
Started by chem55, Dec 20 2010 12:48 PM
No replies to this topic
Posted 20 December 2010 - 12:48 PM
Liquid Nitrogen DistributionStarted by Guest_Estiqaatsi_* , 23 Jan 2024 |
Kettle Reboiler Designe Rules - Position Weir, Height Weir, Liquid LevStarted by Guest_Otthigh94_* , 17 Jan 2024 |
Operation Of Heat Exchanger Above The Overall Heat Transfer CoefficienStarted by Guest_Papps_* , 13 Jan 2024 |
Vessel & Tank Liquid InternalStarted by Guest_Danish John Paul_* , 03 Jan 2024 |
