My references are 500-600 mbars absolute and duration of the stripping > 7 hours for batch size of 30 mt .
For the vacuum pump , consider liquid ring pump .
Xsbr Reactor Design
Started by process-man, Jun 14 2011 06:20 AM
29 replies to this topic
Posted 07 July 2011 - 01:48 AM
#27
Posted 07 July 2011 - 02:19 AM
Any advice on gas flow and power of vacuum pump?
#28
Posted 20 July 2011 - 06:18 AM
Could you advice me for the followings:
-whether or not I shall send the outlet gas of vacuum pump to atomosphere or any recovery section?
process-man
process-man
#29
Posted 20 July 2011 - 07:02 AM
-Normally you will have a barometric condenser and you can recover part of the VOC in the liquid phase ( upon treatment with the other liquid coming from the washing of your reactor you can dispose it or better if possible you reuse the water +VOC for the next batch) , for the remaining depending the regulation in your area you may consider to have it diluted with air .
The other option is to consider to burn all the VOC .
Hope this help!
Hope this help!
Posted 11 November 2011 - 05:37 AM
dear breizh
I just have tested in my pilot an XSBR batch , but I just got a low solid content latex. I was really wonder if you could give me a formulation for my pilot.
best regard
processman
best regard
processman
Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 21 May 2026 |
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
Adsorber Design Essay QuestionsStarted by Guest_Kahirn_* , 10 May 2019 |
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
