Ion Exchange And Chromatography
Posted 25 June 2011 - 07:44 AM
Name's Jopeth, a 5th year ChE student from the Philippines. I'm into plant design and I'm new to these unit operations: Ion exchange and Chromatography. On Ion exchange, my purpose of using this is to separate Na2SO4 from the sugar solution (xylose, arabinose, galactose, mannose, cellulose and xylan to be specific). I don't know how to create a mass balance around nit as it is unsteady state (efficiency is lowered at a time and accumulation follows, same as Chromatography to concenterate xylose from the solution. I'm planning to use dowex ion exchange resins. I've found a software but it's used only in water demineralization purposes. Our plant design is production of Xylitol from corn stover.
Attached herewith is the process flow diagram of our plant.
Any help will be greatly appreciated. thanks!
p.s. Ion exchange for the removal of Na2SO4 is labeled as salt removal. 242198_1886341331333_1625410695_1824142_7060452_o.jpg 190.54KB 24 downloads
Posted 30 June 2011 - 04:07 PM
....I'm into plant design and I'm new to these unit operations: Ion exchange and Chromatography. On Ion exchange, my purpose of using this is to separate Na2SO4 from the sugar solution (xylose, arabinose, galactose, mannose, cellulose and xylan to be specific). I don't know how to create a mass balance around it as it is unsteady state (efficiency is lowered at a time and accumulation follows, same as Chromatography to concenterate xylose from the solution. I'm planning to use dowex ion exchange resins. I've found a software but it's used only in water demineralization purposes. Our plant design is production of Xylitol from corn stover. Attached herewith is the process flow diagram of our plant. Any help will be greatly appreciated... p.s. Ion exchange for the removal of Na2SO4 is labeled as salt removal
In the past I experienced a similar problem running a pilot wet scrubber to treat ~7000 m3 of phosphoric fertilizer reactor gases (containing NH3 and Fluorides). We could not find any other way out but running the installation as steadily as possibly. For instance, water flow from network was not steady; we placed overflowing barrels onto upper floor and supplied water from there. Ammonia content in the gas varied ~10 fold; we started the scrubber just after changing ammonia feed drum, since broad NH3 variation occurred during the change.
Substances are diluted into the liquid hold up of each vessel or evaporator. Suppose a gas concentration A suddenly changes to A'. Gas phase out will get A' quite rapidly, but what about liquid out? It will need time to respond, restoring its concentration from B to B'. Indeed, liquid concentrations depend not on the gas concentration of the moment, but rather on previous gas concentration "history". So making a balance (considering substances in gas and liquid) can be imprecise.
Consequently such inconsistencies could be smoothed out through following.
1. Try to have as steady conditions as possible. This is easy said - hardly done, but worth of tries. Observe operations carefully to trace conditions under which disturbances happen, then try to limit variations. Instrumentation and control improvements may be necessary.
2. Try to limit liquid hold up of the vessels to the extend possible. But these might have limited possibility in modern industrial practice. Less hold up in a vessel may cause another disturbance.
3. Assuming you make the balances on continuous flows by samples and measurements, try to make the stable measurements as long as possible, hoping that natural variations will somehow be smoothed.
I believe No 1 is the most effective and most difficult of the three. But it is a trial and see procedure, requiring patience and open mind. No 2 concerns the case when gases and liquid coexist, which does not happen in all steps of the Xylitol unit.
Besides the unit has some evaporators. The multistage evaporators never obtain steady state, according to (fatty?) words of one colleague. In fact we needed hours to obtain a somehow steady state in a single stage phosphoric acid evaporator.
Edited by kkala, 30 June 2011 - 11:54 PM.
Posted 03 July 2011 - 06:22 AM
Posted 06 July 2011 - 09:46 AM
Try to have conditions as steady as possible and give an interpretation of the results.
Hope of good success.
Temperature Difference In Plate-Fin ExchangeStarted by Guest_Ghasem.Bashiri_* , 03 Feb 2021 |
Performance Analysis Of Ion Exchange SystemStarted by Guest_Muhammad Waqas Hanif_* , 19 Jan 2019 |
Ion Exchange Or Other Membrane Technology For Separation Of SaltsStarted by Guest_ChE student17_* , 18 Jan 2019 |
Column ChromatographyStarted by Guest_koraltptp_* , 22 Oct 2018 |
H2S Analyzer & Gas ChromatographyStarted by Guest_SyedAhmed_* , 10 Jan 2018 |
