Posted 21 December 2011 - 03:08 AM
I will be so thankful if anybody could help me to deside:
I'm designing a case:
Fire case PSV
Fluid: water;
Set Pressure= Design Pressure= 7.5 barg;
Design Temperature= 85 C
Relief temperature is calculated= 181 C < 593 C (carbon steel) , so PSV is applicable.
Should i change the vessel design temperature from 85 to 181?!!!
Posted 21 December 2011 - 03:42 AM
Dear all,
Fire case PSV
Fluid: water;
mm217,
Not at all. Fire case shouldn't be the basis of the vessel's mechanical design.
Fallah
Posted 21 December 2011 - 04:03 AM
Dear all,
Fire case PSV
Fluid: water;
mm217,
Fallah
Fallah;
Thank you very much.
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 21 May 2026 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
Adsorber Design Essay QuestionsStarted by Guest_Kahirn_* , 10 May 2019 |
