I am attempting to create a TPxy diagram for water-acethaldehyde at 400 K (PR package) but I get convergence errors in HYSYS 7.2, could you help to identify the reason ?
Tpxy Water Acetaldehyde @ 400 K With Hysys
Started by twell, Feb 08 2012 06:52 AM
tpxy water acetaldehyde peng robinson vle
Posted 08 February 2012 - 06:52 AM
Posted 08 February 2012 - 12:31 PM
If I had to guess, I would guess that you are asking it to calculate the VLE at a point outside the 2 phase envelope or near a boundary of the phase envelope. I can't tell if that is the case or not based solely on the temperature.
Posted 09 February 2012 - 02:01 AM
at 400 K we are far from critical conditions but this is a binary difficult to model, if you generate a phase envelope with Peng Robinson and vdW mixing rules you'll get poor results, better to use complex mixing rules, models as CPA etc.
I am not familiar with the thermodynamics in your simulator, to give you some data I attach a TPXY for Water Acetaldehyde at 400 K generated with Prode Properties and Peng-Robinson-Uniquac with Wong Sandler mixing rules, you can download a copy from Prode.com and compare the results.
I hope this helps to understand the origin of the problems.
Posted 09 February 2012 - 03:43 AM
Two quick questions - why are you using PR and what are you trying for PXY curve in which you are getting convergence error.
Use any activity coefficient PP e.g. NRTL and use Equilibrium Plots extension unit op. Somebody has already posted this extension in earlier forms, search for it or get it from official support team.
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Importing Component Stream Data From Hysys To Excel Using VbaStarted by Guest_TimL_* , 17 Aug 2018 |
How To Handle Water Byproduct And Man Hydrolysis In The Dbp Solvent RoStarted by Guest_martzian_* , 20 May 2026 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Hysys Separator Carryover Setup And Phase EnvelopeStarted by Guest_powerox29_* , 05 Jan 2026 |
