I'm running a dynamic HYSYS model of a post combustion carbon capture plant which uses MEA (monoethanolamine) solvent. In steady state mode changes in the component efficiences in the absorber appear to have an effect but in dynamics mode this is not the case. If I enter 0, 1 or anything in between the process doesn't appear to be affected.
Can someone with expreience of HYSYS please explain why?
Gordon
Hysys - Amines Absorber Component Efficiencies
Started by gmcgough600, Feb 20 2012 11:29 AM
aspen hysys ccs pcc carbon capture absorber amines absorption co2 dynamics
Posted 20 February 2012 - 11:29 AM
Posted 20 February 2012 - 07:17 PM
AFAIK, when on dynamic simulation, Hysys takes into account the tray configuration/dimension, which in itself will determine its efficiency.
In short, your tray efficiencies will solely depend on how you set up your column internals.
Try to tinker with the tray internals configuration instead.
Posted 21 February 2012 - 05:12 AM
The absorption and regenaration of amines is dependant on operating conditions.
You need amine license to show the effects or you can use spreadsheet to show above effects,
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Using Vector User Variable In HysysStarted by Guest_Ulbert Zsolt_* , 01 Mar 2024 |
HysysStarted by Guest_hysyshunter_* , 12 Feb 2024 |
Some Problems About Running Aspen HysysStarted by Guest_Mohammad3799_* , 05 Feb 2024 |
