A pump is designed for pumping fluid with sp gr 0.6 at pumping temp.
Can the design characteristic curves of this pump be referred to check adequacy of this pump for pumping fluid of a different sp gravity (say 0.8 at pumping temperature)?
Posted 23 March 2012 - 09:36 AM
Posted 24 March 2012 - 01:18 PM
KINGMOON,
If you are looking for the flow versus head curve (Q-H curve), this will remain unchanged for any change in specific gravity. Change in specific gravity or in other words the density of the liquid will change the absorbed power of the pump driver.
Refer to a recent post on the same subject::
http://www.cheresour...n-with-density/
Hope this helps.
Hope this helps.
Posted 25 March 2012 - 02:50 AM
pump curves give you head in terms of ft , meter etc
you have to convert that to pressure by using P=specific gravity X g X h
so you basically use specific gravity to determine discharge pressure for your own fluid
pump curve itself is independent of specific gravity and is usually developed with water as standard fluid
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
