the procedure calculates the hydrate formation pressure & temperature in the range of 220 to 330 K (you may change the units).
According the manual the procedure is able to calculate the hydrate formation curve for "the common hydrate formers (C1, C2, C3. iC4, nC4, N2, CO2, H2S) and several inhibitors (methanol, ethanol, ethylene glycol plus salts in versions including electrolyte model)".
The model is based on CPA, Cubic Plus Association and van der Waals-Platteeuw for hydrates (solid equilibria)
From my tests it would seem that Prode doesn't require to specify the amount of water unless a inhibitor (we use 10% methanol) is included, then the amount of water is required, with the 10% (weight) of methanol the curve has larger values as expected.
In Prode you can include the water in the mixture when large amounts can influence phase equilibria, then Prode calculates phase equilibria with CPA including water.
Our client has a different software which requires to specify the amount of water even when the contribute of water is absent (no water or very small amounts).
Comparing Prode against this software the results are quite in agreement up to hydrate formation pressures of 150-200 Bar while above those pressures the results may differ (possibly CPA model works differently from the EOS included in our client's software).
My question is, could very small amounts water influence the hydrate formation curve ?
Should I specify a amount of water even when there is no water or the amount is very small ?
From my tests with Prode it would seem that below a certain amount of water the hydrate formation curve is not influenced, is my conclusion correct ?
Thanks.
Edited by mrbabu, 02 May 2012 - 01:24 AM.
