Hi all,
I am just beginning my engineering career. I am working on the development of a flow reactor system.
The idea is to use high pressure (up to 1500 psi) to enable higher temperature reaction (up to 500C) and therefore faster reaction times. The system is currently benchtop scale with very low flow rates (on the order of ul/min).
Because of the nature of solvents used in the chemistry (THF, DMF), it is important to use chemically resistant materials for valves, tubing, etc.
I have been trying to find information for multiport switching valves that can operate at high temperatures. The options I have found so far can meet pressure and corrosion requirements, but not temperature.
If anyone has any knowledge in this area to share it would be greatly appreciated
Thanks,
Mike
High Temperature Valve Operation
Started by DMTilley, Jun 21 2012 02:37 PM
valve high temperature seal
Leaking Ball Valve On Hot AmineStarted by Guest_chris_* , Yesterday, 06:36 PM |
Operating Temperature Limit For Shell And Tube Heat ExchangerStarted by Guest_enen_* , 14 Jun 2013 |
Rupture Disc & Safety Valve SizeStarted by Guest_Dchaitanya_* , 12 Jun 2013 |
Safety Relief Valve SizingStarted by Guest_Ali_gholamalian_* , 07 Jun 2013 |
Relief Load Depressurization Valve Vs Relief ValveStarted by Guest_dtmgo1_* , 03 Jun 2013 |
