  • Log in with Facebook Log In with Google      Sign In
  • Create Account
ChExpress Blog - 6/11/13
Read the latest news from the chemical industry in Christa's blog.
Heat Loss from Pipes
Calculation Of Flow At Diff % Openings Through Control Valve
  • You cannot start a new topic
  • You cannot reply to this topic
#1 varun.gupta91@gmail.com
  • 10 posts
Posted 28 June 2012 - 10:47 PM
I m working on a problem i.e if FT fails then how to determine flow corresponding to % opening of valve ,
I have datasheet for the valve and various required values like delta p sizing, cv selected, cv calculated (min/nor/max) etc., so far as I have read I used following calculations bt could nt succeed as results donot match the readings ,so can anyone help plz???
  • Attached File  new.xlsx   16.96KB   41 downloads
#2 sheiko
sheiko
  • 679 posts
Posted 30 June 2012 - 10:18 PM
Are your control valves equipped with positioners?
If not, I believe you should not give too much credit to the % opening readable from the DCS, because it is possibly different from the actual valve opening in the field. But you can make a test to check that.
Edited by sheiko, 30 June 2012 - 10:57 PM.
