  • Log in with Facebook Log In with Google      Sign In
  • Create Account
ChExpress Blog - 6/11/13
Read the latest news from the chemical industry in Christa's blog.
Heat Loss from Pipes
Density Of Ethanol-Water Vapor At High Pressure And Temperature
density ethanol
  • You cannot start a new topic
  • You cannot reply to this topic
#1 kaiaze_i
kaiaze_i
  • 4 posts
Posted 06 July 2012 - 10:02 PM
Is there a correlation to calculate the density of ethanol-water vapor mixture at high pressure and temperature? thank you!
#2 gunley
gunley
  • 13 posts
Posted 07 July 2012 - 04:10 AM
You can calculate it using any EOS. For high pressure Peng-Robinson EOS gives the most accurate results.
#3 kaiaze_i
kaiaze_i
  • 4 posts
Posted 07 July 2012 - 08:24 AM
Thank you! =)
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,025 posts
Posted 07 July 2012 - 01:35 PM
Ethanol-Water mixtures properties should be evaluated using the fluid package UNIQUAC as recommended in HYSYS tutorials. NRTL property pacakge has also been used for ethanol-water mixtures. Peng-Robinson is not the right property package for Ethanol-Water mixtures.
#5 gunley
gunley
  • 13 posts
Posted 08 July 2012 - 03:40 AM
Many times for my assignments I have been using PR EOS, even for ethanol - water mixture, to calculate properties and I always more or less accurate results.
