  • Log in with Facebook Log In with Google      Sign In
  • Create Account
ChExpress Blog - 5/14/13
Read the latest news from the chemical industry in Christa's blog.
Heat Loss from Pipes
Aspen Plus Ammonium Nitrate Missing Property Parameters
ammonium nitrate aspen plus missing property parameters ammonium nitrate model aspen missing data
  • You cannot start a new topic
  • You cannot reply to this topic
No replies to this topic
#1 Delano
Delano
  • 5 posts
Posted 28 July 2012 - 11:29 PM
Hi Everyone
I was hoping that someone could once again save me.
I am trying to create a model of an ammonium nitrate plan in aspen plus but i have come a long the following error.
* WARNING IN PHYSICAL PROPERTY SYSTEM
PARAMETER PLXANT (DATA SET 1) FOR COMPONENT NH4NO3:
UNREASONABLE VAPOR PRESSURE CALCULATED AT TEMPERATURE UPPER BOUND.
VALUE SHOULD BE LESS THAN MAXIMUM ALLOWABLE VALUE
= 0.10000E+36 N/SQM. PLEASE CHECK YOUR INPUT FOR THE
ANTOINE PARAMETERS.
NRTL BINARY PARAMETERS FOR ALL COMPONENT PAIRS ARE ZERO,
YOUR RESULTS MAY NOT BE ACCURATE. PLEASE REVIEW AND PROVIDE BINARY
PARAMETERS AS APPROPRIATE.
Flowsheet Analysis :
COMPUTATION ORDER FOR THE FLOWSHEET:
B1
->Calculations begin ...
WATSON HEAT OF VAPORIZATION MODEL HAS MISSING PARAMETERS:
DHVLWT/1ST ELEMENT (DATA SET 1) MISSING FOR COMPONENT NH4NO3
DHVLWT/2ND ELEMENT (DATA SET 1) MISSING FOR COMPONENT NH4NO3
****PROPERTY PARAMETER ERROR
ERRORS ENCOUNTERED IN CALCULATION OF LIQUID MIXTURE MOLAR ENTHALPY USING
OPTION SET NRTL FOR H
! Calculations stopped because of missing property parameters
I get the same error no matter what property method i choose. Any suggestions?
Cheers
Edited by Delano, 28 July 2012 - 11:30 PM.
