I am working in the wellhead compressor station using seven centrifugal compressors in parallel to boost the inlet pressure of natural gas to available power discharge pressure to purification plant.
Is any body help me to formulate the model in HYSYS to optimize the mode.
Performance Optimization Of Centrifugal Compressor
Started by washoo, Aug 11 2012 06:13 AM
Posted 11 August 2012 - 06:13 AM
Posted 11 August 2012 - 06:54 AM
Washoo,
We would love to help you but before that we would like to know what efforts you have put in for developing the model such as developing a flow diagram or scheme with the process controls as well as providing the configuration of the compressor operation such as 5 operating at 20% rated load plus 2-standby or 4 operating at 25% rated load plus 3-standby or any other combination of operating and stand-by. You obviously don't expect the Cheresources members to build you a model in HYSYS and that too without knowing the configuration that you require and provide it to you.
Lp/hp Flow Ratio Of Centrifugal CompressorStarted by Guest_shan_* , 24 May 2013 |
Leaking Screw Compressor SealsStarted by Guest_u062268_* , 12 May 2013 |
Rv Sizing For Blocked Outlet, Pressure Source Centrifugal PumpStarted by Guest_Ashishtheone_* , 10 May 2013 |
Reciprocating Compressor Unloader ValvesStarted by Guest_Mayank Joshi_* , 06 May 2013 |
Max Differential Pressure On Compressor Suction Temporary StrainerStarted by Guest_mm217_* , 05 May 2013 |
