What is main role of surge tank in close loop process?
Best regards.
M.R.Rahimzadeh
Surge Tank
Started by m.r.rahimzadeh, Aug 14 2012 12:23 PM
Posted 14 August 2012 - 12:23 PM
Posted 14 August 2012 - 02:05 PM
Surge tank
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A surge tank (or surge drum) is a standpipe or storage reservoir at the downstream end of a closed aqueduct or feeder pipe to absorb sudden rises of pressure, as well as to quickly provide extra water during a brief drop in pressure.
In mining technology, ore pulp pumps use a relatively small surge tank to maintain a steady loading on the pump.
For hydroelectric power uses, a surge tank is an additional storage space or reservoir fitted between the main storage reservoir and the power house (as close to the power house as possible). Surge tanks are usually provided in high or medium-head plants when there is a considerable distance between the water source and the power unit, necessitating a long penstock. The main functions of the surge tank are: 1. When the load decreases, the water moves backwards and gets stored in it. 2. When the load increases, additional supply of water will be provided by surge tank.
In short, the surge tank mitigates pressure variations due to rapid changes in velocity of water.
Posted 15 August 2012 - 04:58 AM
surge tank is used for storage of water or any solution. It is the main vessel from where the solution is pumped to main tower..
Posted 15 August 2012 - 06:20 AM
It is normally located between, let say, two process units in order to reduce the upsets due to flowrate variations between them. It dampens the changes in the specified flowrate while keeps the liquid level in the tank between two predetermined limits.
Fallah
Fallah
Posted 15 August 2012 - 06:00 PM
Consider this resource to support your query
Stripping Gas Requirement. Using Flash Gas From Condendate Flash TankStarted by Guest_Dmitry_* , 16 May 2013 |
Hydrocarbon Metering In Tank FarmsStarted by Guest_Supamartin_* , 19 May 2013 |
Difference Between Tank & Vessel ?Started by Guest_sunny0_* , 15 May 2013 |
Hold-Up Time,surge TimeStarted by Guest_ashrath_* , 15 May 2013 |
Relief Surge Tank MarketStarted by Guest_chattingnettie_* , 14 May 2013 |
