  • Log in with Facebook Log In with Google      Sign In
  • Create Account
ChExpress Blog - 5/14/13
Read the latest news from the chemical industry in Christa's blog.
Heat Loss from Pipes
Hc Dew Point Temperature Vs Stream Temperature Of Fuel Gas
  • You cannot start a new topic
  • You cannot reply to this topic
#1 asade abiodun
asade abiodun
  • 146 posts
Posted 29 August 2012 - 03:20 AM
Hi All,
From the fuel gas system HYSYS model I developed, I noticed that the HC dew point of the gas @ stream condition is 62.22 deg.F. The stream condition are temperature @62.23 deg.F and pressure @ 250 psig. The fluid is a fuel gas to be supplied to a GTG.
1) Would this close HC dew point temperature to stream temperature affect the property of the fuel gas to the GTG?
2) Should I consider the installation of a heater to increase the flow temperature when the FG condition required by the GTG is within the range of 45.8 - 48 deg.F and 242 - 250 psig?</p>
#2 RoyenG
RoyenG
  • 22 posts
Posted 16 October 2012 - 07:19 PM
Hi Asade,
you need to see the lowest temperature in the plant area,
at the stream conditions (62.23 degF; 250 psig) there is no problem, but there will be liquid formation at the lower temperature caused by environment.
installing heater or heat trace the line is common for fuel gas supply to the users (boiler, etc)
RoyenG
