I have a rupture disk on the discharge of a positive displacement pump. The rupture disk is equipped with a link so that we can stop the pump when it bursts. However in the immediate 1-2 seconds after the disk bursts:
- the pump shutdown takes 500-1000 milliseconds discharging several gallons of liquid
- the depressurization of several thousand feet of downstream pipe generates several additional gallons discharge of "incompressible" liquid
The problem is that this system runs at 200bar. When the disk bursts, the liquid jet is quite dangerous to operators. (There are no toxic or volatile materials in the liquid.)
Can anyone suggest a design for a blowdown drum to contain such a discharge?
My current thinking is
- cyclone shape, open at the bottom so the liquid can drain
- large air vent line at the top
- infeed (rupture discharge line) tangential entry into the tank
All suggestions are appreciated.
High Pressure, Short Time, Blowdown Drum Design
Started by docdan, Sep 07 2012 03:50 PM
blowdown psv rupture disk relief safe discharge
Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 21 May 2026 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Completed High School And Really Interested In Chemical EngineeringStarted by Guest_B0DER_* , 14 May 2026 |
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
