Provide me any relavant literature for the pressure drop across molecular seal and velocity seal in flare stack.
Seals In Flares
Started by sharjeel39, Sep 18 2012 05:37 AM
Posted 18 September 2012 - 05:37 AM
Posted 18 September 2012 - 05:52 AM
Dear Sharjeel,
This is propritery item manufactured by the vendor. There is no as such stanard available for the pressure drop across the molecular seal & velocity seal. You have to approach vendor only for same. Flow rate & composition will change flare to flare so, not possible to provide standard pressure drop for the molecular seal & velocity seal.
Posted 22 September 2012 - 03:52 AM
Dear Sir,
I totally agree to you that its purely a vendor item and i have asked different vendors about this and all of them are giving me different pressure drops, the gas flow is 15MMSCFD and it contains H2S and CO2, i believe the composition has nothing to do with the perssure drop but still.
I am not sure whom to trust because the pressure drop, different vendors have provided me, varies from 2 psig to 11psig.
For this i need assistence so that I can evaluate the correct pressure drop.
Posted 22 September 2012 - 11:47 PM
Shejeel,
Is this seal is molecular seal or velocity seal ? I think it is in psia not psig. Pressure drop is always in absolute. Generally Pressure drop for the molecular seal is high compare to velocity seal.
As per me 2 psi is ok but 11 psi is very high. What is a back pressure of flare header ?
What pressure you have provided to flare vendor to design the flare system componenets?
Posted 23 September 2012 - 10:05 AM
Jatin,
I know this that pressure drop is indicated in absolute its a typo error but still thanks.
I have considered velocity seal and the header pressure is 50psig.
Flare Study And Pump SealsStarted by Guest_Sue N_* , 21 Aug 2023 |
Flares Tips DesignStarted by Guest_georgesnanga_* , 15 Mar 2023 |
Psv Discharge To Different FlaresStarted by Guest_Shaileshprocess_* , 06 Mar 2023 |
Compressor Dry Gas SealsStarted by Guest_ianmcq28_* , 24 Feb 2015 |
Dry Gas SealsStarted by Guest_washoo_* , 17 Jul 2014 |
