Edited by premjagan, 12 November 2012 - 06:41 AM.
Material Balance Of Secondary Reformer
Started by premjagan, Nov 12 2012 06:37 AM
secondary reformer
Posted 12 November 2012 - 06:37 AM
Help me to calculate the secondary reformer outlet material balance on wet basis.
Posted 13 November 2012 - 12:47 AM
You need to first of all put all the reactions.
CH4+O2=CO2+2H2
CH4+1/2O2= CO+2H2
And then calculate all accordingly your input rate, kg/hr or m3/hr.
simple.
CH4+O2=CO2+2H2
CH4+1/2O2= CO+2H2
simple.
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
Psv Body Material Of ConstructionStarted by Guest_QuantumEng_* , 07 May 2024 |
Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
